RCU Forums - View Single Post - OVERHEATING!!
Old 11-22-2006 | 01:32 AM
Ron Olson's Avatar
Ron Olson
Default RE: OVERHEATING!!
You could be either running to too slow so that it isn't getting enough cooling water to the head or you have a blockage somewhere in the cooing system. It doesn't take much, a little algae or other crud can block the waters flow. Check by blowing through the cooling lines to narrow down where the problem might be.
