RE: Another Myth busted?
does anyone actually fly the models?
Some theory guys apparantly just jerk off and read bench results .
The in air cooling has NOTHING to do with prop pitch- -
It has to do with air flow thru the cooling fins - and the engine -if fully cowled --will cool-or- get hot depending on the setup used
all the engine cares about is load and cooling- prop size means squat.
