RCU Forums - View Single Post - Another Myth busted?
Old 11-22-2006 | 11:17 AM
daveopam's Avatar
daveopam
My Feedback: (9)
Default RE: Another Myth busted?
Downunder, I would like to see the following experiment. Set your 45 up on a test stand. Directly behind the test stand set up a prop balancer with a 13x6 or whatever you have on hand. Run each of your two props up to 12,000. Then get a tach reading from the prop on the balancer.The tach reading should tell which of the two is pushing more air.
David
