RCU Forums - View Single Post - Another Myth busted?
Old 11-22-2006 | 02:00 PM
Flyboy Dave's Avatar
Flyboy Dave
My Feedback: (21)
Default RE: Another Myth busted?
I think that low pitch prop business is another myth. I think the 3D guys are circulating
this myth, because they use low pitch props.
It is not possible for a lower pitch prop to give more thrust than a higher pitch prop,
unless the high pitch prop is stalled...or as a water prop...cavatating.
If you were to draw that out to it's logical conclusion....a 1" pitch prop would deliver
more static thrust than an 10" pitch prop.
I don't think so. The more pitch (thrust angle) you have in a propeller, the more thrust
you will have at any RPM.
Besides that, what good is static thrust ?....a measurement of how hard you cal pull on a
fishing scale ? That measurement, and a two dollar bill will get you a cup of coffee
almost anywhere.
FBD.
