RCU Forums - View Single Post - radio setup on showtime
Old 11-23-2006 | 12:10 AM
RTolle
Default RE: radio setup on showtime
Set your standard dual aileron mix. Then using mix4 set the elevator as the master and either the gear or flap as your slave. (whichever you don't use for the aileron mixing.) The 4th mix has inclusive trim and you can adjust each half individually. This has been working very well on my X100 and showtime. And a buddies been using it for his sukhoi.
