RE: Prop Load Factor (PLF)
power is simply an expression of work produced.
Watts old Horsepower formula still confuses many.
In a nutshell, you can't calculate prop efficiency with any real degree of accuracy.
you can only measure it
The interaction with the airframe - can easily reduce all the carefully developed data to garbage.
Or re stated -- the prop efficiency must be developed to suit the task.
