You're not alone...
After a successful range check, I lined up and took off. The aircraft lifted and turned as it should. Really nice and majestic like... Went out to the end of the field and banked left, well almost. The aircraft rolled and found the only log anywhere on the field, and created the event where I choose my username... Seems I had never extended the antenna after the check and simply flew out of range. Real brainy...
Ed
