RCU Forums - View Single Post - FS One by Hangar 9
Old 11-23-2006 | 05:29 PM
  #476
MSelig's Avatar
MSelig
Default RE: FS one by Horizon Hobbies
Sorry to hear that.
Humm....
When you did it the second time, did you download the patch new from online? Or did you use the one you downloaded the first time? I'm wondering if the file was corrupted first time.
The current patch (1.0.4) has a new exe file and some typo fixes in a few txt files. So if you try it again, what I suggest is making a copy of your working FS_One.exe file in the install directory, and then install the patch. The patch will give you a new FS_One.exe file. If things create trouble again, then go back and use the prior exe file (your copy).
This is definitely puzzling. Just so you know - this is the only report of an issue at this point. The brand new fresh install that I did from the ground up was on an HP machine - Intel.
Michael
