RCU Forums - View Single Post - tt 46 pro eats glow plugs
Old 11-23-2006 | 08:09 PM
piper_chuck's Avatar
piper_chuck
My Feedback: (12)
Default RE: tt 46 pro eats glow plugs
ORIGINAL: cbr954rr
I have a GP dazzler that i put a tt pro 46 on. I have about 15 flights on it now. Since new it has leaned out in the air. I set it with a tach on the ground 400 shy of peak and take it up for a 6-7 min flight and all is well...
While there are mechanical reasons for the glow plug to fail, the most common is running the engine too lean. What's the plug look like at the end of a flight?
It would be good to get to the bottom of the bubbles you said you saw. In addition, the tuning method you use might be resulting in lean flights. Following is the way I prefer to tun my engines.
Tuning – High speed needle
The following method is designed for sport flying where one wants reliable engine performance (minimum deadsticks) and long engine life (part of which comes from avoiding lean runs).
I’ll start off with a reminder that all needle adjustments should be done from behind the engine and that the plane should be firmly anchored or held. Never attempt to adjust the needle while holding the plane in the air. A small engine blip or wind gust could result in fingers in the prop.
Begin by gradually leaning the engine until you find the peak RPM. Once you find this, turn it several clicks rich. Once you’ve found this slightly rich setting, with a firm two handed grip on the plane, point the nose straight up. While you are doing this, remember to keep the propeller arc out of anyone’s face. When you raise the plane’s nose, one of three things will happen to the engine RPMs.
If the engine speeds up slightly and holds that speed for 10 to 15 seconds, pat yourself on the back (after you put the plane down), you’ve got the needle set pretty well.
If the engine slows down, or does not speed up a bit, it’s too lean. Lower it immediately, turn it a few clicks richer and try again.
If the engine speeds up significantly, it could probably be a bit leaner. Put it back down, set it a bit richer and try again.
That’s it, no magic…
