RCU Forums - View Single Post - CMP Quest 50 ARF----????
Old 11-24-2006 | 09:57 AM
tIANci's Avatar
tIANci
Default RE: CMP Quest 50 ARF----????
kloper - i tried out the CG just now, 105 mm and I noticed it cannot be correct. For a swept back LE wing the CG at the root is about 40% to 45%. I am using a SA72 and I guess It should come out just right. My CG is about 130 mm measured at where the wing meets the saddle. I will see how she flies tomorrow morning. Set my rates using the JR 9Xs flight mode, got a very low rate on FM0 so in case she is tail heavy I can still bring her in.
