RE: Ryobi 31cc engine setup
Just a little update......I picked up some gasket material and fitted the backplate and the head/crank case gaps with new gaskets. The engine is 95% ready to go, just need to get the choke plate and cut it down to fit. Also, I picked up an engine off of an old wacker for future use. Its a Poulan Weedeater GTi 16, but I have absolutly NO idea what kind or size engine this is, any ideas? The engine turns over nicley, the carb is Walbro and looks very clean but is missing a high end needle valve, but its a "short shaft" engine so I dont know if that would be a varying factor. Well if you have any ideas as to what it may be, let me know! Thanks and happy holidays.....
Colin C
