ORIGINAL: RCKen
ORIGINAL: Wild Foamy
... a scale cub should be ok....
Actually, most Cubs do not make good planes for beginners to fly. And especially scale Cubs. A lot of people will look at a Cub and assume that because it's a high wing plane it will fly like a trainer, but this is completely wrong. Cubs have a few bad habits that make them a "handful" to fly for even experienced pilots, and for beginner's it can frustrate them to point of getting out of the hobby. A couple of the worse habits associated with Cubs is squirrely handling on the ground and adverse yaw in the air when making aileron turns. When making turns in a Cub the pilot really needs to make coordinated turns using the ailerons and rudder to make for a smooth turn. Coordinating the two control surfaces is something that comes with experience and is usually a bit much for the beginning pilot. For these reasons I always recommend that Cubs be avoided by beginning pilots.
Ken
I'm with Ken. I flew a 1948 J-3 Cub, and I own a H9 Cub. You better know how to use that rudder on your turns. Coordination with the rudder, ailerons and elevator is a must for a smooth turn.
Peter Dowling aka Luftwaffe Oberst
AMA District II # 865404
Aero Modelers Club
Pulaski, NY
