RE: BVM UAT HELP
I have used the UAT in the vert position with no problems. If you can, fill the UAT for the first time thru the center cap fitting, this fills the filter media from the inside out purging the air. Run the motor and shake the jet to be sure there are no more air bubbles otherwise it will ruin your day.Also leave the UAT full for the next flying session.
V..
