ORIGINAL: hobbydude214
ah yes i didnt even realize to warn against that. i relly didnt even use the insructions much but i did see that. one tip for advice never use epoxy or hot glue on a foamie, for one reason they both are heavier and only epoxy is stronger but not worth the weight gain, and 2 if you get a lot of moisture on hot glue it tends to break apart from the surface
I used hot glue to hold the servos down on my BYP YAK by E-Flite and with 50+ flights, the servos are still intact. I really push the BYP YAK and the hot glue hasn't failed yet.
