Eagletalon -
A couple of things are going to help here.
[1] Install the latest patch to get up to 1.0.4. This will fix the calibration problem that you're having.
http://www.inertiasoft.com/fsonefaq/#Q1005-FS1
[2] Look at this FAQ item to see how to setup the 9303. I use the 9303 all the time and the setup works well:
http://www.inertiasoft.com/fsonefaq/#Q1013-FS1
If you take this approach (use the 9303 to emulate the TacCon controller), it will be "user friendly." One model memory on the 9303 can be used to fly all the aircraft in FS One. Each aircraft that you pick will automatically pick up it's "software radio" with it's own specific flight modes/mixes. If you don't like the D/R and expo settings for a particular aircraft, then make a copy of the Tx setup and edit those settings.
This should get you going again.
Michael
