RE: Miglet brushless setup help
To all on the "MIGLET"YES nice look little plane "wing" if you will. I have one and It flys just GREAT and handle nice. I'm at or about 3000 feet above sea leavel and incounter problems with initial take of as I try to lanch with on hand and the other on the radio. It sweeps down real low as if it's lacks power, But once it get a moveing it is fine. I normally have a friend lanch it off for me so I can catch it before it hits the ground. I'm useing the normal setup as laid out by GREAT PLANES with a 3 cell 1320 thungerpower under the canopy. There is barily enough room to put everything.
QUESTION: I want to put a HIMAX 2025-5200 kv motor in place of the stock. OK, Does anyone see anything bad with that setup that might not work and would I feel that much in the takeoff power. According to the manual that comes with that EDF it states that the eeflux speed with a 48000 KV brushless is about 217 MPH. Will I see a greater increase in the eeflux speed? .............Will that motor (Himax 2025-5200 KV) be too much. Questions,Questions.......HELP im lost in the R'C world.
Your Fiend Dolan"wingman" G.
