RE: PIcs of WILD THING RUN from hpi build
I added a pad for the tank. I do remember seeing some foam when I brought in to check for fuel.
Hope i can get out tomorrow and get it figured out. Ill run it with no changes other than the pad to see if this was the problem. Then I will mess with the needles again. First by tryin to richen up the HSN and check the temp on the shore warm it up good. I think I might pinch the water line off further to get some more heat in the motor. Dave
