RCU Forums - View Single Post - Senior Pattern Association- Northeast chapter forming
Old 11-27-2006 | 10:48 AM
kingaltair
Default RE: Senior Pattern Association- Northeast chapter forming
ORIGINAL: Dean Pappas
But, here's my problem: I'm looking to build a plane that I think will be legal, given what I hear is being accepted, but nowhere in the rules on the SPA site can I find these allowances spelled out. Arguments ain't fun, unless we agree to fly together anyway afterward, and if the plane ain't legal ...
Whether you are inside the event or outside, unclear rules are stinky. If the event is to grow into other parts of the country, this will be a problem.
There was an attempt to create a 3% Rule, but that proved to be difficult to enforce, (and who wantes to go around with a ruler checking every detail in order to "let somebody have it" anyway). We adopted the "Duck Rule" mentioned earlier--if it looks like a duck, it's a duck. If you want to use a plane for both VR/CS and SPA, I'm positive you will get no arguements from SPA folks, as VR/CS rules are more strict. There is certainly nothing wrong with bringing a plane built to planform to an SPA meet--most planes are original, or very close to the original---it just seems there are lots of mods since that is what everyone wants to talk about in these forums. There will be very few problems/arguements unless the plane has had major mods, and even then you would probably be politely asked to bring a different plane next time.
My "advice" (though I'm sure you don't need it), would be to select a plane close to the 1970, (for VR/CS purposes), cut-off date, with a vertical hinge line for the rudder so "knife edge" won't be a problem. Most late '60s designs were quite advanced, and will fly fine without changes. Most common SPA changes involve small enlargements of the engine compartment to accomodate the 4-stroke engine, (if desired), and a slight lengthening of the fuse.
Bottom line---if someone decides to modify something, make it small, (the smaller the better), so the plane retains it's original look.
My King Altair needed a different rudder for SPA--other than the canopy, that is the only obvious change. Fortunately Vic Husak thought it was a reasonable change.
