RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 11-27-2006 | 01:40 PM
  #986
RingWinger's Avatar
RingWinger
Default RE: gas fuel with glo plug no ignition
Hello Andy,
Micro Needle Bearings:
I don’t doubt you skills to be able to create a needle bearing, but I think you’ll find that it is much nicer to buy this product.
There are many sources for these bearing and I have attached a PDF showing a listing of micro needle bearings.
Micro Needle Bearing PDF: http://www.impactbearing.com/brochurepg30.pdf
Store Front: http://www.impactbearing.com/needlebearings.html
Note the smallest on this PDF is for a 0.118 shaft and the outer dimension is 0.256. It would be extremely unlikely that you could make such a precision bearing without complex grinding equipment to create these various components. This bearing is rated a 46,000 RPM.
You can look here for more Micro Bearing store locations: http://www.thomasnet.com/nsearch.htm...sec=prodsearch
I completely agree with you on the need for a needle bearing on the piston end of the rod. This will allow for the use of low cost fuels and much reduced oil content.
Various fuels:
I have run a mixture of 20 methanol and 80 Coleman Lantern fuel mixed with Cool Power oil. I found that the Cool Power oil is low cost at $7.50 per quart in the USA.
I purchase the oil from Horizon Hobbies at this location:
http://www.horizonhobby.com/Products...?ProdID=COO500
I had difficulty finding a cost effective synthetic oil that would hold methanol and Gas/Lantern fuel together. To my great delight Cool Power Oil does a wonderful job and it leaves my engine and airframe clean after extended runs.
I have run this mixture in both my gas conversion engines and my glow engines. It does run much hotter than plain methanol. The fuel has a very high energy content, burns clean and has a very pleasant odor that reminds me of nice evenings reading by a Coleman powered lantern.
I also use the Wal-Mart brand of lantern fuel called Ozark Camping fuel and it cost about $3.80 per gal USD.
Have fun,
Kelly
