RCU Forums - View Single Post - Multi servo control surfaces
Old 11-27-2006 | 04:32 PM
exeter_acres's Avatar
exeter_acres
Default RE: Multi servo control surfaces
Sorry Bax and Krysta for posting,,,delete if you need to...
Devin, which radio?
if it is the 12 or 14z then simple use a seperate channel for each servo and set up end points and throw for each one
I use a 9C on a similar set-up and I use the MAS-10 from Futaba.
Works perfectly for matching servos together......
