ORIGINAL: zackesch
i like the eclipse 7. also, i looked at polk tracker III, but i herd their radios are still iffy and it dosnt have the mixes that i want. since the eclipse 7 has 7 memory spots, and when i get more then seven airplanes, is there anything wrong with righting the presets on a piece of paper, then program the one you are going to use in the slot of an aircraft that you are not using?
example: i have 7 planes in the radio, but im bringing 2 that are not programed in the radio. so, i put them in the slots that i am not using and wright over it. "i am going to keep all the setings on all aircraft written down.
Either of the planes you listed will fly any sailplane you want. IF you want a full complement of mixes with full support for a 4 servo wing, then get the 9C Super!
