RE: PIcs of WILD THING RUN from hpi build
I took her out again today ran pretty darn good. I fattened the HSN up and put the pad under the tank. I noticed that the feed line might have had a little cut where I had pushed it on the tank so I pushed it further on. It was pretty choppy today when I first started to run it. I seadunked her once and spun out once The seadunk was my fault I let of the throttle at the wrong time. The spin out was a fast run but I was running with the wake coming at the side the boat. After I put 2 or 3 more tanks through it. It calmed down[>:] now it was time to beat her hard. I refueled and sent her out held her wide open for about ten laps right through the turns no problems. Then I brought her in to notice the engine came loose I wish I had the money to buy a 3mm tap when I rebuilt the mounts. Darn nylocs going to have to loctight them. Other than that ran great.
