RE: Motor weight to power issue. Help?
Thank you Matt.
The plastic pinion I have on will be very easy for me to remove, but the new pinion, it sounds, will be a challenge to put on?
It sounds like the 6:1 ratio may be the way to go. Do you recommend the ESC300 or ESC350? Do you think I could maintain 5 minute flights on my current batt -- 730 mAH 7 cell NIMH?
I have also seen e-Flight has a 370, but I don't know about the weight on that one.
If I go 6:1, what prop size do you recommend?
Jeremy
