RCU Forums - View Single Post - Ryobi 31cc engine setup
Old 11-28-2006 | 10:19 PM
  #50
predator500
Default RE: Ryobi 31cc engine setup
ORIGINAL: mikenlapaz
I have two Ryobis mounted with 16oz tanks. That amount of fuel will run engine for well over 20 minutes with a reserve to spare. I chose use the space inside fuse for other things and saved having to carry around that extra fuel weight.
Sorta like trimming off the extra metal weight off engine.
Did you open up the reed valve limiter abit to about 1/8" allen wrench thickness?
If you mean that little flap on the backplate then yes I did.
I know, 24 does seem a little much, maybe Ill go smaller, like a 16 if your saying that will give me 20 minutes flying time.
Anyways, anybody know what type of engine that is yet??
Colin C
