RCU Forums - View Single Post - how do you hover?
Old 11-29-2006 | 02:29 PM
SkyUp's Avatar
SkyUp
Default RE: how do you hover?
ORIGINAL: Karyn
As Vince said, increase throttle to lift heli into air.
Then,
if heli turns left, push rudder stick right... (left hand stick, same as throttle)
if heli slides left, push cyclic stick right... (right hand stick)
whatever the heli does, do the opposite on the sticks to keep it stable...
This all sounds very easy, but the heli will move faster than you can react. No really, it will. It you react directly to what you see then the heli is already moving... by the time your thumbs catch up with your brain and you move the sticks the heli is moving fast. This means you'll push the stick too hard/far and overcompensate, sending the heli off in the other direction.
The skill is in predicting what the heli is going to do and preventing it. This is something you can only learn by doing it.
All of the above, use Radd's and a sim (if you have one) until you suddenly realize that "You need to Control the heli", rather than react to what it does ... it's a mindset only acomplished by practice and patience ... but once you transcend this barrier, it gets much easier (and more fun).
