RCU Forums - View Single Post - how to avoid bouncy landings?
Old 11-29-2006 | 05:20 PM
Charlie P.'s Avatar
Charlie P.
Default RE: how to avoid bouncy landings?
ORIGINAL: fayrwerks
Any tips on how to avoid bouncy landings?
One observation. Trainers have very weak and bendy gear - to absorb abuse. After a few splats the main gear is splayed out, the nose, with the spring & generally stiffer wire, less so. This gives the wing positive incedence when the wheels are touching. Enough so, quite often, that the plane has a tendency to want to lift off again. Take the time to set the plane on a table and make sure the wing has a bit of negative incedence, or the flat bottom of the wing is at least parallel with the table.
In the past I have rigged 12# pike leaders or weed trimmer line across my wire gear to stiffen them up.
