RCU Forums - View Single Post - how to avoid bouncy landings?
Old 11-29-2006 | 07:50 PM
  #32
opjose's Avatar
opjose
Default RE: how to avoid bouncy landings?
ORIGINAL: darock
The trick to using them is to drill and tap the plywood that was holding the blindnuts for the metal bolts. If the plywood isn't thick enough, glue in some basswood to get thickness.
So you don't advise screwing the nylon bolts into the blindnuts?
Thanks.
