Setting Twin elevator servos using 9CAP
I'm highly disappointed that my 9CAP PCM doesn't have " conditions" ala JR's 9 Ch XP 9303. Through super accurate mechanical setups ,one can "nearly " identicalize servo distance from the hinge line , measure total throw deflection in degrees , and set up the ailevator function as per the manual to get things moving in the proper direction using a separate servo for each elevator half , BUT without a conditions menu , one servo can never mirror the other through the full range of up/down motion. I prefer not to use Matchbox type devices , so I guess I'm S.O.O.L. ! Am I wrong , Mr. Futaba ? If so , tell me how to do it.
