RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair
Hi guys
If you are both going to add gear and strut doors, I would offer a suggestion, in your manual page 15 steps 12 and 23 make sure you drop the gear mount beams down into the wing, at least 1/8 at the spar end and 5/32 or more at the other end, and plan on mounting the gear right out at the fwd end of the beams so metal frame and mounting screws just clear the underside of the wing skin. This will save you a lot of time later when fitting your gears,
Cheers Bob T
