RE: Don Smith A-26
Glad to see you moving forward Dave. every little bit counts. Good idea the pink foam; I wondered the same as Ichy,are you going to install the lower turret?
Ichy: I checked out your forum at scalebuilder, Beautiful idea the use of the pinpong ball on the landing light. Are you going to coat it with resin or will it stand the heat of the bulb. Did you use a mini or a micro servo to actuate the retract sequence?
Again my hat's off to all of you, wonderful job so far.
Eric B.
