RE: Range Check Problem
" all the servos started to jump when the receiver was in front of the plane at 10-15'. " Did you mean to say, " when the transmitter was in front of the plane " ? How does it perform with the transmitter behind, or off to the side of the plane. The flying wires could be blocking the signal from the front. I had this same problem with some complex wire landing gear. I had to run the Rx antenna up to the fin. Try running it out to a wing tip.
> Jim
