RCU Forums - View Single Post - Range Check Problem
Old 12-01-2006 | 09:07 AM
NM2K
My Feedback: (14)
Default RE: Range Check Problem
ORIGINAL: chuck l
Well, I'm not having much success, just lots of frustration. I epoxied the rigging wires on the top center section so they wouldn't rub and the interference is still there. It was 20 degrees out yesterday and prop wash on the hands was a killer, so testing was short. Removing the antenna from the fuselage didn't help either. The interference does increase with engine speed. I've done a little searching and found several comments regarding the rigging acting as an antenna creating interference on a biplane, and that a PCM receiver should be used. The supplier of the plane also said to use PCM. I've always tried to eliminate interference and fly a plane with PPM before switching to PCM, but it's starting to sound like that might not be possible. Does any one know much about flying wires causing interference on biplanes?
I've got a few more things to try yet as the process of elimination continues.
Chuck
Switch out the conductive rigging wires for Kevlar rigging wires.
Running metal, or other conductive material, rigging wires is asking for trouble. The radio waves and the RFI from the engine will be reradiated by the wires.
Also, the original signal from your Tx will be reflected multiple times (multipath in radio jargon) and will confuse the decoder in your receiver.
Ed Cregger
