RCU Forums - View Single Post - Range Check Problem
Old 12-01-2006 | 09:36 AM
dirtybird
Default RE: Range Check Problem
I was at an IMAA fly in where a modeler had the same trouble with a 1/3 scale Sopwith Pup. He had changed to a PCM receiver and claimed he solved the problem.
On his first flight the receiver went into PCM hold and he lost the airplane.
If you want to fix the problem change to non conductive wires.
