RE: Range Check Problem
Chuck, if you have solid contact with the aircraft from the rear or sides, then it's not RFI or vibration related. Your flying wires are simply shielding the incoming signal when you stand in front. You have got to get your Rx antenna reoriented. Try it out to a wing tip, or go to non conductive wires.
> Jim
