RE: SPE 26 problem
It is not good break in weather for a aircraft engine in open air at 25 degrees. Before you start it wrap cylinder with a shop towel and tie it there with heavy string. It will warm up quicker and start running at more favorable temps. Just do not let it overheat with a heavy ..high load. Only run short 2-min runs and vary RPM. See if that helps. Capt,n
