RCU Forums - View Single Post - Typhoon 2000 engine
Old 01-25-2003 | 03:48 PM
Scott Smith's Avatar
Scott Smith
Default Typhoon 2000 engine
Originally posted by snsmith
I'm presuming this is for glassing...does the Typhoon need to be glassed for stiffness, durability, etc.? I've done some glass work, but not an entire ship. How about the wings, should they be glassed as well? Thanks again!
I recently wrestled with that question as well in finishing my Patriot. I decided to glass the whole thing. I’m using Gator Feather Lite cloth, thinned West System epoxy (blotting with tp), Polycrylic filler coats (2) and have primed w/System 3 (Nelson) epoxy primer. I have done the wings, ailerons, elevators and rudder (fuselage is a little behind in construction) Total weight increase through primer is 5oz. So far I think I’ve made the right decision.
BTW, if your thinking of using Nelson Paints, order the Paint Trial Kit from System Three. For $15 you get enough primer and white to get you well on your way plus lots of other goodies and documentation.
