Typhoon 2000 engine
Hmmm...I might take the plunge and give glassing a try. The glassing I've done before was with water-based polyurethane instead of epoxy, after using sanding sealer on the balsa (to reduce the amount of poly sucked up by the balsa). I've only done this on small wings, any reason why polyurethane won't work for a 2M pattern ship?
