RE: Bdavison's E-flite Blade Assembly
just looking at the pic on the right the pitch seems to be downward by several degrees. is this a rebuild from a crash? did your heli just start doing this? did you unplug any of the servos from your 4 in 1? if you did you may want to check the sevros as per your manual and check on all the connections. also check your pitch.[8D]
