RCU Forums - View Single Post - kero start with Li-ion battery
Old 12-03-2006 | 01:57 PM
mr_matt's Avatar
mr_matt
My Feedback: (10)
Default RE: kero start with Li-ion battery
ORIGINAL: samo
Hi Matt,
I had trouble starting my P-70 Kero start in 25 degree weather. How does the cold affect the starting process. Is it diminishing the effectiveness of the battery -or - is it the kero plug and turbine - or - all of the above? We'd really love to keep flying even if it's cold but but have run into this problem. (using both the stock 2400Nicd and the NimH 3300 ECU battery)
Thanks for your help,
Steve
Hi Steve,
This temperature should not be a problem for the turbine (they have been tested to much lower temperatures).
First, what is the specific symptom? Does the start time out (slow acceleration?) or is it low battery signal?
In any case, the most likely culprit is the battery. Are you sure it has a fresh charge?
Regards,
