ORIGINAL: jaskel
I thought ABS was not as slippery as PVC??? But as magnat said; ABS is slippery as hell untill it is worn in, then it drifts niocely....
DO a couple batteries wearing it in, then get into it.
Spot on
ABS still has a Slippery outer coating
When this gets worn away , your left with a Rather Grippy Plastic Surface..
You should have the Outer Coat worn away in about 20 mins depending on Pipe Used and surface Drifted on..
