RE: Separate gyro and Rx
Yes, It's a Futaba 9CHP.... a (9) channel - (C)omputer - (H)eli - (P)CM. It's got the synthesizer module so you can select whatever channel you want to use via a couple of trimpot-style microswitches on the back side. And yes, it has provisions for the eCCPM 120 degree swash, so it'll work fine with the CP. There's also a thread on this forum that detailed programming this the 9chp for the CP.
