RE: YS 61 on the pipe...prop?
Gee mate can't you read. I am sharing my experience on the using a fuel pressure system that gets the engine to perform through all of a flight and I don't know if you noticed, the start of the thread asked about a prop!!!!! and I stated that the Schimitar prop did give good performance on the Aurora.
What is your angle on your question? I don't have anything to do with the Fuel Pressure manufacturer, is that your point? Isn't this forum designed for sharing experience? I just supplied a bit more information through a positive experience. This system is NOT just based on the fuel tank getting pressure but the fuel supply is based on demand from the engine and not the pressure forcing it through to the carby. It can be fitted to ANY 2 stroke or 4 stroke engine. If the engine stops, the supply to the engine stops.
