RCU Forums - View Single Post - Got a problem with the 7202 transmitter
Old 12-03-2006 | 08:16 PM
rajul's Avatar
rajul
Moderator
My Feedback: (58)
Default RE: Got a problem with the 7202 transmitter
You will need the mono adapter http://www.ikarus-modellbau.de/onlin...ca088.63839801 to work with JR radios. You must set the radio to PPM mode as well. If the radio does not switch on automatically when you plug in the adapter into the trainer port, switch on the radio manually but remove the xtal or module.
