RE: positive traction problems
play dough is better, pack it inside the diff, will keep the gears from turning so bolth wheels will spin evenly, if you dont like it then you can take the play dough out, jb weld is pemanent. if you lock it up, it wont handle as well around corners since both wheels will be turning at the same speed.
