RE: Figures
There are a lot of reasons.
A. Are you at sea level? If you above sea level thrust will be lower at any RPM.
B. Most of those thrust HP softwares for models are far too simple to give a good answer. The calculations are not based on real life test of the props.
C. The method you are using might not work well.
D. All of the reasons Ed gave.
