RE: Help With Eagle 50 Simulation Cable
Well I was going to fly it however I needed to shut off the CCPM mode since I didn't like the way it makes the helicopter handle, now it functions as a fixed pitch helicopter, however I have control over the pitch of the blade by manually changing the setting on the control knob. I wasn't able to fly it however it had a bad tail motor, I have to replace it and then tune the helicopter. I also shut off the thing that keeps the head spped constant, I have found that the helicopter is easier to control with that off. By the way the dip tab on the back for Norm/ccpm is backwards, so if you go fly it try switching it to normal mode it helps alot.
