RCU Forums - View Single Post - Air Hogs Aero Ace!
Old 12-04-2006 | 12:26 PM
  #3860
ahaacobbler
Default RE: Air Hogs Aero Ace!
I just spent some time modding the new controller. I got the three channel switch to work. I thought it was all downhill from there. I went to solder in the p11 connection and the connection broke loose from the board. Has anyone modded out a new controlller? Tim
I can't remember which one is P11, but I had the contact that both diodes conect to in the no throttle turn mod rip off while I was making said mod. There was nothing to reattach to and the TX was junk without that contact. I traced the line around the borad to the other side where I found another solder dot on the line. I connected a wire to that dot and ran it around to a resistor near where the contact broke off. The TX is as good as new now.
