ok so i now have the xtals switched. here is my problem...everything works the way it is supposed to except the throttle, there is no response. i went into the program and reversed the throttle(from where it was) and still nothing. the 3 in 1 will not arm, but, if i put the throttle all the way up and wait the 3 in 1 will arm, then if i move the throttle to a lower position both motors wll start up?[:@] so it is like the left stick needs to be flipped. but like i said this will only do this if it is reversed(now normal). if the switch is reversed back even on full throttle it will not arm. i am stumped [
