Can a plane go out of range?
For the typical major brand radios, the statement that "if you can see it you can control it" is correct. However, many of the parkflyers do have a limited range and I've seen many of them go out of control yet be quite visible. Whether or not you use FM or AM, the range is the same and determined solely by the receiver sensitivity assuming the same power out from the transmitter.
