Can a plane go out of range?
two most common... come in too slow, stall and break anything from wing to snapping the fuz, depends on height
come in too fast, if a tail dragger it'll nose over and you might bust the tail.
The "must do if your a newbie with a trainer" come in too hard, bend the nose wheel slightly then it'll never take off again and prop strike on every bump
